Hoverboard remote controlled
06/19/2024 at 14:12 • 0 commentsBLDC controller made with IRF3205 mosfets and IR2101 mosfets drivers. BLDC PWMs are generated from 18F2550.
Both BLDC controllers are commanded from a main board with another 18F2550 which can be accessed from Android(USB/WIFI) or PC(USB).
One more time this can be controlled in long distance through WebRTC by mounting the Android statically and accessing to it from another mobile or PC, allowing to view through the statically mobile camera.
Remote TCP/USB control through WebRTC
03/02/2024 at 16:28 • 0 commentsRemote control (client-device)
The server can control multiple client devices by P2P (camera, TCP/USB device)
Control multiple USB/TCP devices in the distance.
Create a RTC_Host using RTC_Host_App and connect to it through RTC_Client_App.
Then connect some TCP/USB device to mobile where RTC_Client_App is running and prepare the desired responses to the received commands from TCP/USB device.
Customize this responses with the value to receive from RTC_Host_App.
RTC_Host_App will detect the available commands for the control of TCP/USB device connected to RTC_Client_App and will put a control interface like switchs, potenciometers or a joystick.
RTC_Host_App can activate the RTC_Client_App camera too.![]()
PC / Android web (camera, USB device)
Android App (camera, TCP/USB device)
Web version:
https://stormcolor.glitch.me/remote-control/client-device/
Remote control (server-device)
Multiple clients can control the server by P2P (camera, TCP/USB device)
USB devices connected to single RTC_Host_App can be handled by multiple RTC_Client_App.
From RTC_Host_App the number of players with device access allowed in a single round and when next round should be triggered can be configured.
Clients can view the scene with the server webcam.![]()
Web version:
https://stormcolor.glitch.me/remote-control/server-device/ -
Robot controlled by WebRTC (PC-mobile)
08/08/2023 at 20:34 • 0 commentsRobot controlled by WebRTC from PC (4G router) to mobile device. Is not under wifi. I can to controll this from kilometers.
Mobile communicate with MCU by USB or ESP8266 (to have the mobile connected to a power bank)
Using a free TURN server to avoid CGNAT in both (Robot & PC). -
TCPUSB PCB
03/28/2023 at 04:00 • 0 comments![]()
final schematic for TCPUSB mode (not ngbrain)
03/26/2023 at 21:21 • 0 comments![]()
remote control by WebRTC
03/26/2023 at 07:42 • 0 commentsI maked remote control for the vehicle using WebRTC.
I have a website hosted in Glitch where I've running NodeJS+WebRTC.
First user that enter in website application acts as WebRTC server and this have controls to drive the client vehicle.
JETSON in vehicle has connected a WIFI adapter and this adapter is connected to mobile ISP data.
When Jetson verify for internet connection opens Chromium and load the Glitch website as second user (client). Then it make P2P pair with server, share webcam connected to Jetson and then active WebUSB to communicate Chromium with the microchip MCU by USB.
Server can previsualize the client webcam and send commands to it by WebRTC DataChannel.
Now the vehicle has the following functions:
- Automated drive by detecnet pursuing silhouettes.
- Short distance remote control by two ESP8266 modules (Access point in remote controll and Station in vehicle)
- Long distance remote control by WebRTC and the ISP data.
Now I need to see how I going to attach batteries (which I don't have) :)
If some day we are confined again (I hope that doesn't happen) I will be able to see what happens in the street xDDD
remote control ready
02/05/2023 at 15:41 • 0 commentsRemote control ready and setted to RC or USB modes only. I thinked I can drive a big vehicle sitting using remote control directly and I don't need two manual controls separately.
remote control by ESP8266
02/02/2023 at 18:25 • 0 commentsvehicle quering to remote control about desired config (gearedmotor/BLDCcontroller & USB/manual/RC controll)
Added direction switch
01/16/2023 at 08:33 • 0 commentsSchematic changes to add direction switch. Firmware also ready but still need the RF code.
I'm going to investigate now to create FM transmitter/receptor :D.
schematic for geared motor or BLDC controller
01/15/2023 at 20:02 • 0 commentsMaking two modes for TCPUSB class controller.
Using BLDC controller for big vehicle (manual control, RF or Jetson_USB)
or using geared motors for little vehicle (RF or Jetson_USB)
3drobert
