Seeking help to build an RC airplane, 3D printed, 3 surfaces, low wings, electric engines close together in tail.
Description:
- An electric canard aircraft with 2 propellers close to the centre line (to minimize asymmetry if one engine stops).
- The configuration has short landing gear (low C.G.), heavier wing loading, and a wide stance for stability on take offs and landings.
- The canard can make the main wing "stall proof".
- Extremely simple, as there are no flaps or ailerons. The wing tips on the tail surfaces rotate like stabilators to provide pitch, roll and yaw.
- If this were a full size aircraft it could be very quiet inside and outside due to propellers being located far aft, but not in the wake of the main wings
