First please check the 4 minutes video where everything is clearly demonstrated and explained.
Link : https://www.youtube.com/watch?v=3ESE02ywSxQ
This display does an impossible task ! it keeps the image ALWAYS facing the spectator whatever the angle of observation !
EVERY spectator at the SAME TIME have the impression that the display is following his direction..
That have some applications like in Halloween where frightening figures can be made to appear following everybody. No one can escape his gaze.
The effect is impressive but the principle is very simple : a cylinder with a vertical slot and a printed sheet of paper. The cylinder is rotating at high speed and a source of light is at the top.
Files
distort.pde
Code that can be imported in Processing (processing.org).
Please note that this code works under Processing version 3.
This program will distort an image in order to be correctly displayed by the prototype I used ( Pringles Can).
See video description of the project (4 minutes long) : https://www.youtube.com/watch?v=3ESE02ywSxQ
The most difficult
problem I encountered is the suppression of vibrations due to high
speed of rotation.
As you can see in
the video I used hot glue to fix the system to my computer’s case.
In order to
stabilize the system we can use the same solution used in certain
cdrom drives and washing machines : some ball bearings that are
free to move at the periphery of the rotating cylinder.
