Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Sign up Log in
TinyPlayer
IR Remote Controlled MP3 Player based on ATtiny13A and DFPlayerMini
stefan-wagnerStefan Wagner
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
3 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
328
0
3
1
Team (1)
  • stefan-wagnerStefan Wagner
Join this project's team
  • Project Files (Github)
  • Project Files (EasyEDA)
completed project
hardware
attiny attiny13 ATtiny13a dfplayer mp3 audio ir avr arduino pcb
This project was created on 06/17/2021 and last updated a year ago.
Description
TinyPlayer is an IR remote controlled and LiPo battery powered MP3 player based on ATtiny13A and DFPlayerMini module. The DFPlayer module is controlled via a simple cycle-precise software implementation of the UART protocol (8N1, 9600 BAUD) in half-duplex mode. The volume last set as well as the track number last played are saved in the EEPROM and automatically loaded the next time it is started. TinyPlayer has a built-in battery charging circuit, which is supplied with power via a USB-C connector. You can directly connect a 3.7V LiPo battery and a 3W/4Ohm speaker to the board.
Details
Log In/Sign up to comment
Sign up with Github
OR
World's first open source and modular phone kit
Project Owner Contributor
Seeedstudio RePhone: Fun & creative modular DIY sm
ediyeDIY
The uninterruptible power supply module with battery charging and protection, for building smart devices with power paths' redundancy
PS4IoT_V1 Smart Power Supply Unit Module
iot-devices-llcIoT-devices, LLC
U3 is a FIO bootloader running at 3.3v. LIPO battery charger, battery regulator, NRF24 plug
U3 project from arduIoT .com
dimitri-synodinosDimitri Synodinos
Small battery for your ESP8266 devices.
Coin Battery Shield for D1 Mini
dehipudeʃhipu
Going up?
© 2023 Hackaday
Yes, delete it Cancel
You are about to report the project "TinyPlayer", please tell us the reason.
Send message
Remove Member
