uCharger
A tiny LiPo charging module that can be used for adding portability to projects
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
The uCharger is a compact LiPo charging module for single LiPo cells with incorporated over-charge and over-discharge protection. The module can be used as a standard SMD component on any circuit board or as a standalone for fast prototyping. Features: - Over-charge protection (4.2V) - Over-discharge protection (stops power when the battery reaches 3.0V) - Programmable charging current from 130mA to 1000mA - Status LEDs - Surface mountable
