1Step 1: Mark where you want to drill your holes
I used a silver Sharpie but you can use whatever you want as long as it shows up on the board clearly!
2Step 2: Use a center punch to get your holes ready to be drilled!
I used this center punch to make starting points in the board where I had marked with Sharpie. If you don't have a center punch you can skip this step. I find it useful to use one whenever my drilling needs to be precise.
3Step 3: Drill your holes!
The drill I had wouldn't hold the small drill bit I needed so I ended up using a dremel.
4Step 4: Insert O rings and earrings
I used some simple split rings and fishhook earrings you can get at any craft store! Woohoo! You're now the proud owner of some bad-ass blinky earrings!
