Hackaday.io Hackaday.io
Sign up Log in
Robot
An arduino based robot
bigbatbigbat
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
2 comments
3 followers
  • Description
  • Details
  • Files 2
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 2
View Gallery
Public Chat
175
2
3
7
Team (1)
  • bigbatbigbat
Join this project's team
completed project
ROBOT arduino speech remote
This project was created on 08/23/2021 and last updated 4 years ago.
Description
My son asked me if I could build him a robot. So I did, but then he said he wanted a robot that can speak, walk on its own and also be remotely controlled. So a few years later... yep, this robot emerged :-) The heart is an Atmel processor on a PCB. In the head is a small breadboard with a shift register for the lights. A servo motor controls the head and 2 DC motors control the movement. An arduino speakJet shield is used for the sound. In the head there is a IR distance meter to avoid obstacles. In the back there is an IR receiver for the remote control. The robot can listen to commands from the remote (when its nose is turned off) or run on its own. The arms do get in the way though, so avoiding obstacles results in falling sometimes :-)
Details
Files
robot.pde
the code for the arduino
pde - 16.17 kB - 08/24/2021 at 11:00
Download
robotSchema.fz
the electronic scheme in Fritzing
fz - 517.65 kB - 08/24/2021 at 10:59
Download
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
davedarko wrote 08/24/2021 at 09:28 • point
ah that's a cute one :)
bigbat wrote 08/24/2021 at 11:02 • point
Thanks! :-)
The 2016 Hackaday Prize
Robot control in ultrasonic and simple alarm pir and system calcule distense in ultrasonic and lcd
Project Owner Contributor
Arduino
micro-technology-makerMICRO Technology MAKER
Janus Jr is a small five-bar parallel robot designed to work with brushless motors, ESP32 (Arduino IDE) and 3D printed parts.
Five Bar Parallel Robot - Janus Jr
david-gonzalezDavid Gonzalez
You'll learn how to construct your own autonomous mobile robot with movable shaft through servo-motor
Introduction to autonomous mobile robots
fcodiegomoreirafcodiegomoreira
A 5-bar robot with variable geometry to dinamically ilustrate changes in the spacework of the robot based on its dimensions
Modular 5-bar robot
juan-salvoJuan Salvo
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "Robot", please tell us the reason.
Send message
Remove Member
