1Run a Program
// The setup function runs once when you press reset or power the board
volatile int i=0;
void setup()
pinMode(2, OUTPUT); // sets the pin2 as output
pinMode(1, OUTPUT); // sets the pin1 as output
pinMode(0, OUTPUT); // sets the pin0 as output
void loop()
for (int i=0;i
