SubLEq Revisted
I have some unfinished business!
SubLEq Revised ============== Recently there has been a pick up in interest in SubLEq. I don't know why, it is a horrible CPU concept! But with a few years of experience with CPUs perhaps I can do better than last time. So how about a practically useless 4-bit version that can count (and not much else). LogiSim ======= This time I will teach myself LogiSim. AlanX
LogiSim
Basically I am using SubLEq to teach myself LogiSim.
Is it even possible to get anything useful out of a 4 bit SubLEq.
Actually, yes I can get a 4 bit counter working in LogiSim.
74XXX Libraries
You will need some external 74XXX libraries. I used 74xx Libary.circ (https://github.com/kara-abdelaziz/CHUMP-processor/) and logi7400ic.circ (https://github.com/r0the/logi7400). Did not find a library that was complete.
I found and error in logi7400ic.circ for the 74161. The clock input was inverted. I modified my version of the library to fix it. Taking down this error took many hours.
From Concept to Working Simulation
I am impressed, about 15 hours over three days as a LogiSim novice.
Structure
LogiSim encourages the user to design your circuits hierarchically. Both with "bit width" and sub-circuits. As SubLEq is difficult to understand this is a good approach.
Programming SubLEq
Here is the binary counting program I am trying to implement:
Address A B C
0 0 1 3 Z = 0
P = 1
3 1 0 6 Z = -1
6 0 F 9 B = B + 1
9 0 0 3 Z = 0
C 0 0 0
F 0
I/O
Usually address -1 or in the case 0xF serves as Input/Output or output in this case.
Note: A write to the I/O address also write the value to memory.
SubLEq has only one instruction:
  1. Mem[B] = Mem[B] - Mem[A] and  jump to C if the result is Less or Equal to zero.
Decoding the Binary Counter Program
Address Comment
0             0,1,3 ;Set up Z (=0) and P (=1)
Usually this is written:
0            0 1 ?    ( ? means the very next address)
3            1 0 ?    ( 1 is the count increment, set Z = -1 )
6            0 F ?   ( Increment the output address 0xF )
9            0 0 3   ( Reset Z = 0 and jump to address 3 )
C            0 0 0  ( Not reachable but: Reset Z = 0 and jump to address 0 )
F            0         ( The I/O address )
I am sure you all got the above and can now program in SubLEq.
Where to Start?
The timing diagram. I can do this because I have a bit of an idea what the sub-system look like:
Lets put this into steps:
Timing Micro Code Clock
T0 MAR=M[PC]
T1 ALU_A=M[MAR] PC++
T2 MAR=M[PC]
T3 ALU_B=M[MAR]
T4 M[MAR]=ALU_OUT; !WE; PC++
T5 IF (LEQ) THEN PC=M[PC] ELSE PC++
Don't be misled, although I present a linear process, it is still iterative.
The ALU
The ALU is fairly simple:
Subtract: B = B - A
Flag: !LEq
Therefore we need:
  • Load A: !ALU_LDA
  • Load B: !ALU_LDB
  • Read B - A: !ALU_OUT
And because of the type of control logic I am using:
  • Clock: CLK
  • Reset: RST
Here is my schematic:
Chip Count:
  • 2x 74HC173
  • 2x 74HC283
  • 1x 74HC04
  • 1x 74HC125 (the inverter and tri-state output buffers)
The  beauty of LogiSim is that you can test the sub-circuit before proceeding.
Program Counter
The program counter is perhaps the simplest sub-circuit to design. Note: the outputs PC0-3, these are for debuging LED display in the top level:
Note: the 74161 in the logi7400ic.circ library has the clock inverted. I have edited my version of the library.
Memory Address Register (MAR)
The idea behind the MAR is to load a value from memory and then use that value as an address to load an indirect memory value. Thus it is a form a indirect addressing.
Note: the MAR0-3 outputs are for debugging.
Output
Output for SubLEq is a little tricky,...
Logisim-2.7.10.jar
x-java-archive - 25.08 MB - 09/11/2021 at 03:03
Download
4BITv2.circ
circ - 45.74 kB - 09/11/2021 at 03:03
Download
4BIT.circ
circ - 45.60 kB - 09/11/2021 at 03:03
Download
TEST.TXT
plain - 78.00 bytes - 09/11/2021 at 03:03
Download
Portable Network Graphics (PNG) - 26.06 kB - 09/09/2021 at 04:06
Preview
View all 24 files
  • Update to Input/Output Logic
    agp.cooper09/09/2021 at 04:17 0 comments
    Adding Input to the IO Sub-Circuit
    To add an input port I had to move the address out the output port and memory address to 0xE. The input port will use memory address 0xF but the memory select will be disabled:
    Here is the updated top level schematic:
    The binary counting program now reads the increment value for the input port upon start up. Therefore the input should be set before reset and run.
    Here is the program:
    Note: Line 9 (Jump 6) is redundant.
    Am I going to build this CPU
    No, the main purpose of the project was to learn LogiSim and to try out a CPU hardware control logic system.
    Fixed the logi7400ic.circ library for both the 74161 and 74173 now.
    AlanX
View project log
agp.cooper wrote 04/04/2022 at 23:27 point
Thanks Michael,
Subleq is horrible - Don't do it!
A much more interesting and powerful and yet not yet finished, is my CHUMP V5.
Useful with only 4 bits!
It need a Load Effective Address (swap PC/ACC?) and Von Neumann architecture (self programmable, swap memory banks?).
Regards AlanX
Michael Möller wrote 04/04/2022 at 11:48 point
You may have re-awekend my SubLeq - in Real Hardware - project. A quick glance at your emulation shows you seem to have saved a clock cycle. I need 6 for normal, and 7 for branch.
