The Swallow Programming Language
Swallow is an easy to use systems programming language with python-like syntax. Repo - https://github.com/Swallow-lang/swallow
Public Chat
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Swallow
Swallow is a compiled programming language currently under development.
Why am I creating this language?
I am creating it as a fast alternative to python and as an easy alternative to c
Goals
- Ease to use
- Fast
- Highly modular
- Occupies less memory
- Compiled
How does it work?
You can consider it to be a superset of c which compiles to clean c. So valid c code is also valid swallow code(the language is named swallow). It will have no garbage collector because it is a system programming language but it will be very easy to use so there will be less chance of memory leak
