Mini Bartender Robot Arduino Base Code.txtBase code you can use on Arduino as starting point. Might need to tweak a few things if you place the servo horns at slightly different spots on the servo teeth but this is the foundation. Have fun!plain - 16.03 kB - 09/19/2021 at 01:55 |
2021_01_29_Full parts set.gcodeSTL file of all 3D printed partsgcode - 44.64 MB - 09/18/2021 at 22:41 |
Mini Bartender Robot BOM (1) (2).odsList of off the shelf components required to assemble bartender robotspreadsheet - 39.71 kB - 09/18/2021 at 04:31 |
