Autonomous glider
Designing of an autonomous glider using PCB provided by JLC.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
We at Team Onyx India are delighted to be able to use the PCBs provided by JLC PCB. The PCBs are dependable and perform flawlessly. We're building an autonomous glider aircraft and need a PCB to make it smaller and faster. JLC PCB has provided us with high-quality PCBs, which we appreciate. The team also requires PCBs to design Powered Autonomous Delivery Aircraft. The Aim is to land the autonomous Aircraft in the landing zone using image processing. The team also requires to design a Ground Transport Vehicle to deliver the payload carried by our primary aircraft. JLC PCB https://jlcpcb.com/RAT
