Homemade Leyden bottle-super super simple capacitor
To put it simply, the Leiden bottle is a capacitor, a device for storing charge and electric energy composed of two electrodes made of conductors that are close to each other and insulated from each other! Okay, let’s start making now~~
The materials are as follows:
*Tin foil (change according to the size of the Leiden bottle~~)
![](https://cdn.hackaday.io/images/4841331632297982911.png)
*One bottle, preferably a glass bottle
~The thinner the better~
![](https://cdn.hackaday.io/images/5713101632297998064.png)
*Salt and water (the greater the concentration of salt water, the greater the capacity)
![](https://cdn.hackaday.io/images/2047901632298017699.png)
*One stainless steel nail or iron rod~~(change according to the size of the bottle~)
![](https://cdn.hackaday.io/images/2634691632298055845.png)
OK! Let's make it~
![](https://cdn.hackaday.io/images/3806881632298072453.png)
First cut a piece of tin foil with the size of the side area of the bottle~
![](https://cdn.hackaday.io/images/6837671632298092796.png)
Roll it up
![](https://cdn.hackaday.io/images/524321632298106024.png)
Tie it tightly with tape, but leave a small gap at the top to allow a small piece of paper to be inserted into the tin foil, and you will know what it is for later~
![](https://cdn.hackaday.io/images/9162191632298151773.png)
Pass the nail through the middle of the bottle cap
![](https://cdn.hackaday.io/images/9503821632298164405.png)
Just dress like this~
Okay~ That gap is useful~
![](https://cdn.hackaday.io/images/7357891632298198466.png)
Cut a small piece of tin foil~
![](https://cdn.hackaday.io/images/6438321632298216191.png)
Insert it from the gap~
![](https://cdn.hackaday.io/images/3767901632298252736.png)
Then bend it like this, note: the tin foil strip must have good contact with the tin foil!
![](https://cdn.hackaday.io/images/8797871632298389289.png)
Then just fix it~
Then again~
Start configuring salt water!
![](https://cdn.hackaday.io/images/6923241632298467349.png)
Bring the water and salt over~~ nonsense...
![](https://cdn.hackaday.io/images/7516201632298494890.png)
Pour the salt into the water, the water at this time is very turbid
![](https://cdn.hackaday.io/images/3554181632298515779.png)
Recent photos ~ ~ very muddy
Stir quickly!
![](https://cdn.hackaday.io/images/3708851632298538572.png)
Very good~ the salt is melted!
![](https://cdn.hackaday.io/images/2026681632298554741.png)
Then ~ pour the salt water into the bottle!
![](https://cdn.hackaday.io/images/7823141632298573066.png)
Just pour it to full
![](https://cdn.hackaday.io/images/2242091632298599700.png)
Then~~exciting
~Twist on the cap~
Finished~ Don't worry, there are two more steps~
1: Perfect~
![](https://cdn.hackaday.io/images/4617171632298619660.png)
If it is used as a high-voltage capacitor, it is best to help the Leiden bottle a perfect match.
Uh... I almost forgot there is one more step
2: Experiment success or failure~
The Leiden bottle is very simple, it will not fail very much.. But still have to try it~ If possible, the capacity can be measured. The higher the salt concentration, the higher the capacity~
