1Pair the remote
Follow the instructions of your remote
2Disassemble the remote
Carefully remove the plastic of the remote, the battery and keep the electronic board
3Solder a wire to each right side pin
Solder to the right side pin when holding the remote upward
4Solder a wire to the power side
Solder a wire on the GND of the battery, and a second one on the voltage
5Link the button wires to the RaspberyPi
Connect the other side of the button wires to the GPIOs of the RaspberryPi
6Link the power wires to the RaspberyPi
Connect the power wire to the 3V and GND pins of the RapsberyPi
7Bonus: connect to domoticZ
Use the uploaded script to drive the remote from domoticz
8Step 8
