Materials needed:
opt101 X1
LED X1
Hole board several
Wire number
1.First take a hole board:
2.Then insert the opt101 photosensitive IC in a good position
3.Then solder...
4.Insert the LED to continue soldering
5. This is the back of the LED connected
This is the front view of all welded:
This is the circuit diagram:
