MultiBench Back (External PSU).jpgExternal 24V 5A power brick (rear)JPEG Image - 219.17 kB - 01/18/2022 at 23:38 |
MultiBench Back (Barrel Jack).jpgExternal PSU (Internal)JPEG Image - 250.21 kB - 01/18/2022 at 23:38 |
MultiBench (External PSU).jpgOverview showing size when using an external power brickJPEG Image - 100.85 kB - 01/18/2022 at 23:38 |
MultiBench.scadOpenSCAD script for building all partsscad - 16.47 kB - 01/18/2022 at 23:22 |
MultiBench Back (Jack).stlBarrel Jack input to back instead of full PSUStandard Tesselated Geometry - 353.01 kB - 01/18/2022 at 23:21 |
PSU Wiring.JPGPSU NVVV (or equivalent size) 24V 120W PSU, 3A Switch, XT60 Female Plug and in line fuseJPEG Image - 325.41 kB - 10/15/2021 at 23:32 |
Power Meter and DPS3005 Wiring.pngWiring for meters, binding posts, barrel jack, DPS3005 and 12V/24V selector switchPortable Network Graphics (PNG) - 661.40 kB - 10/09/2021 at 23:48 |
DSO150 and MP1584.pngDSO150 Oscilloscope buck convertor connection and screw positionsPortable Network Graphics (PNG) - 331.48 kB - 10/09/2021 at 22:31 |
3D Model.pngImage of all 3 model files connectedPortable Network Graphics (PNG) - 168.07 kB - 10/09/2021 at 19:54 |
Voltmeter and Continuity.pngConnection Diagram for Voltmeter, Continuity Checker (AtTiny85 board), selector switch and postsPortable Network Graphics (PNG) - 755.48 kB - 10/09/2021 at 19:32 |
AtTiny85 Continuity Build.pngEverything you need to build a continuity tester, including code. (also see separate continuity.ino file)Portable Network Graphics (PNG) - 347.01 kB - 10/09/2021 at 17:35 |
Continuity.inoVery simple AtTiny85 Digispark board code for creating a continuity tester (just add active buzzer and ~50ohm resistor)ino - 1.44 kB - 10/09/2021 at 17:33 |
MultiBench PSU.stlBack case for a 24V 120W NVVV PSU 159 x 98 x 38 mmStandard Tesselated Geometry - 380.84 kB - 10/07/2021 at 21:44 |
MultiBench Face.stlComponent mounting panelStandard Tesselated Geometry - 699.59 kB - 10/07/2021 at 21:44 |
MultiBench Back.stlCan be a back to either the face or the back or used to join bothStandard Tesselated Geometry - 353.40 kB - 10/07/2021 at 21:44 |
