Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Sign up Log in
vacuum
my progress with vacuum systems experiments
3drobert3drobert
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2 comments
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 7
    • View all
  • Instructions 0
  • Discussion 2
View Gallery
241
2
0
0
Team (1)
  • 3drobert3drobert
Join this project's team
MISC
ongoing project
This project was created on 10/11/2021 and last updated 10 months ago.
Description
Goals: sputtering, dopping, SEM microscope and more...
Project Logs
Collapse
  • vacuum system schema
    3drobert • 12/14/2022 at 18:19 • 0 comments
  • firsts connections for turbomolecular pump
    3drobert • 12/14/2022 at 15:41 • 0 comments
  • waiting for this firsts connections
    3drobert • 11/18/2022 at 18:00 • 0 comments
  • TPH-170 turbo pump + TCP-380 controller
    3drobert • 11/17/2022 at 19:35 • 0 comments
    Startup test for Pfeiffer TPH-170 turbo pump with TCP-380 controller
  • TCP 380 controller
    3drobert • 05/11/2022 at 05:55 • 0 comments
  • TPH 170
    3drobert • 03/18/2022 at 12:06 • 0 comments
    before move I was received the vacuum pump. Now waiting turbo :D
  • rotary vane vacuum pump
    3drobert • 10/18/2021 at 21:03 • 0 comments
    less for it to arrive and begin to enter the magical world of atmospheric emptiness :)
    (0.067Pa)
    Already I'm going saving for the UHV chamber and the turbomolecular
View all 7 project logs
Log In/Sign up to comment
Sign up with Github
OR
3drobert wrote 12/14/2022 at 18:19 • point
Hi Michael. I don't saw your comment. Thanks for the warning.
I tried it for a quick moment only to check if controller was working after the buy.
I need to prepare the vacuum system with all correct conecction now. Already I have one roughing pump to make preliminary vacuum. I will follow the next steps:
I'm going to make rough vacuum with turbo->chamber valve opened but the valve for the roughingpump->turbo closed.
Later when 1*10-3 is reached I will close turbo->chamber valve, start pump for the turbo and then open the roughingpump->turbo valve.
Later I will start the turbo.
Later I'm going to close the roughingpump->chamber valve and then open the turbo->chamber valve.
https://hackaday.io/project/182104-vacuum/log/214291-vacuum-system-schema
I will make the system and steps described in the next youtube video:
https://youtu.be/-DsF6dDbGyo
Michael Fortner wrote 11/22/2022 at 02:01 • point
Be careful with your turbo!  Operating without a roughing pump and in open air can be destroy it.  There's nothing quite as gut wrench is hearing one spin up and suddenly go chug and die.
The BeeHaven is a climate controlled beehive cover to help overwinter bees in cold climates. It's an IoT monitor and controller.
Project Owner Contributor
The BeeHaven
phil-malonePhil Malone
DRV 10983 bldc controller
Blue-ESC : DRV 10983 bldc controller
yj-kimYJ Kim
A simple fish tank refill controller with can bus and extra security
Tank Refill Controller
marcel-ochsendorfMarcel Ochsendorf
A bluetooth drop-in replacement SNES controller
NRF51-based SNES Controller
drew-taymanDrew Tayman
Going up?
© 2023 Hackaday
Yes, delete it Cancel
You are about to report the project "vacuum", please tell us the reason.
Send message
Remove Member
