Crystal RGB
Glowing RGB crystal
3D printed RGB desk ornament in the shape of a crystal. I found a pretty design on Thingiverse and wanted to put an RGB LED in it.
Hardware
Arduino sketch - Crystal
#include <Adafruit_NeoPixel.h>
#ifdef __AVR__
 #include <avr/power.h> // Required for 16 MHz Adafruit Trinket
#endif
#define PIXELPIN          0
Adafruit_NeoPixel strip = Adafruit_NeoPixel(1, PIXELPIN, NEO_GRB + NEO_KHZ800);
void setup() {
  // put your setup code here, to run once:
  strip.begin();
  strip.clear();
  strip.show();
void loop() {
  // put your main code here, to run repeatedly:
  static uint8_t i = 0;
  strip.setPixelColor(0, Wheel(i));
  strip.show();
  delay(20);
  i++;
uint32_t Wheel(byte WheelPos) {
  WheelPos = 255 - WheelPos;
  if(WheelPos < 85) {
    return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  if(WheelPos < 170) {
    WheelPos -= 85;
    return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
  WheelPos -= 170;
  return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
Alternate Arduino sketch - Minerals
#ifdef __AVR__
#endif
#define PIXELPIN          0
#define R   30
#define G   80
#define B   220
void setup() {
  strip.begin();
  strip.clear();
  strip.show();
void loop() {
  static uint8_t dir = 0;
  uint16_t r, g, b;
  r = R * cos(i * DEG_TO_RAD);
  g = G * cos(i * DEG_TO_RAD);
  b = B * cos(i * DEG_TO_RAD);
  strip.setPixelColor(0, r, g, b);
  strip.show();
  delay(20);
  if (i == 60) dir = 1;
  if (i == 0) dir = 0;
  if (dir == 0) i++;
  else i--;
Credits
Thanks to https://www.thingiverse.com/JustinSDK3d.
  • 1 × Micro-USB Digispark compatible board Small Arduino-compatible board
  • 1 × WS2812B Addressable RGB LED
  • 1 × Micro-USB cable Electronic Components / Misc. Electronic Components
  • 2 × M3 screw
  • 1
    3D print components
    3D print the crystal base from Thingiverse. After this is done, start printing the crystal itself and while it's doing that we will assemble the electronics in the base.
  • 2
    Put in Digispark
    Use two M3 screws to fix the Digispark to the 3D printed base. You might have to use a little force.
  • 3
    Add RGB LED
    Hot glue the LED to the base. Align the LED's marked corner to the bottom right, like in the image.
View all 11 instructions
ty wrote 10/19/2021 at 04:23 • point
Fun and very clean, the next thing I would probably do would be some fancy variations based on some random type of sensor maybe (like changing frequency based on barometric pressure?)
mihai.cuciuc wrote 10/19/2021 at 15:42 • point
Thanks for your suggestion! I was thinking of adding a light sensor to dim it during the night, but turning it into an actual indicator of something sounds fun!
ty wrote 10/20/2021 at 01:11 • point
No problem, and wherever you go with it have fun!
