OpenMicroHydro
What if you took the integral of a Pelton wheel?
Open Source, laser cut, high efficiency (tbd) micro-hydro wheel.
This is the result of a weekend project at a family friends house.
It is a laser cut water wheel created by taking a cross section of a Pelton turbine and positioning that curve such that the water streams follow it for the duration of the 1/60 rotation of the wheel required.
A nice video showing a classical Pelton turbine:
Pelton turbines can achieve upwards of 93% efficiency in converting the energy of a stream of water to rotational energy.  This project will not achieve that.
Due to the various losses I have had to introduce (water escaping off of the vanes and less than 90 degree incident angle required for the jets/vanes), I am expecting this project to land somewhere around 80% efficiency. Converting this to firing at the vanes from the inside might mitigate 10% of those losses.  Might.
My target output power for this project is 50-1200W.
Lots of media, no time to put it up yet.
Soon.
  • 1 × Harbor Freight 800w generator.
  • 1 × Acrylic
  • 1 × Fasteners..
  • Yet another project on hold.
    Daren Schwenke02/24/2022 at 04:03 0 comments
    After completing all the actual hard work, digging two sediment catch pits, fixing a trencher, trenching, and actually laying the pipe needed to generate the needed head pressure, we had to move on before I could actually assemble the prototype.. days after I finished it.
    At least Don has a working drainage system now, so I guess that works.
    I do have a lot of media for this.  Some of it may get posted.
    This was actually a good idea. 80% efficiency of a 93% efficient system and you can laser cut it is nothing to sneeze at.  Someday.
  • Live development..
    Daren Schwenke11/12/2021 at 19:25 0 comments
View all 2 project logs
