MakerBee is a 555 timer controlled vibrobot. The 555 is a timer IC used in it's astable multivibrator mode which causes the LED and the vibrating motor to go on and off at a particular time for short duration or in intervals which causes it to move like a bug. It is powered by two coin cell batteries. The eyes of the bot have a breathing LED effect i.e the LEDs fade in and fade out.
Made at Maker’s Asylum by passionate makers who not only love making things but also passing on their knowledge and sharing skills. Maker’s Asylum is India’s first open makerspace that started out of a little garage back in 2013 and over the years has trained thousands of people on skills related to hardware, design and programming!
Start your maker journey with the Maker Bee! #makersgonnamake
![](https://cdn.hackaday.io/images/5789931638618803156.png)
![](https://cdn.hackaday.io/images/325391638618816678.png)
![](https://cdn.hackaday.io/images/8017701638618860385.png)
![](https://cdn.hackaday.io/images/2576371638618886940.png)
