They write about our GGreg20_v3 module on Twitter
11/06/2022 at 22:09 • 0 commentsOur clients spoke about the features of using the GGreg20_v3 module. We are grateful for the high rating!
Thank You!
@IoT-devices, LLC Team
Kyiv, Ukraine, Europe
The GGreg20_V3 back in Stock on Tindie!
11/05/2022 at 23:02 • 0 commentsOrder your #GGreg20_V3 Ionizing Radiation Detector by @IoT-devices, LLC module on Tindie today!
News Source:
GGreg20_V3 lab tests
10/24/2022 at 14:01 • 0 commentsThe next batch of #GGreg20_V3 Ionizing Radiation Detector Geiger counters are being tested at the @IoT-devices, LLC laboratory in Kyiv
Site: GGreg20_V3 Product Page
Also is available on Tindie:
https://www.tindie.com/products/23904/
#radiation #geiger #counter #geiger-counter #Ukraine
Connecting the GGreg20_V3 Geiger counter to the Home Assistant Server via ESPHome
09/20/2022 at 18:30 • 0 commentsWe offer you the procedure of connecting the #GGreg20_V3 Ionizing Radiation Detector Geiger counter (sensor) in combination with the main controller ESP8266 or ESP32 to the Home Assistant server via the ESPHome plug-in.
If you already have experience setting up and deploying devices in ESPHome running Home Assistant, you can skip the introductory sections and go straight to the example of a configuration yaml file that you can use as a basis for your own system and devices.
All sample files are working and run on a real-deployed server and controller ESP8266 with a GGreg20 Geiger counter. ESP32 is also supported by ESPHome and on the example of ESP8266, the reader can make a variant of the yaml file for the ESP32 platform. In this publication, we demonstrate how to work with ESP32 in a limited way, because in terms of ESPHome and Home Assistant settings, the ESP8266 and ESP32 platforms are almost the same...
Read the Full Story at:
Minor hardware changes in the Geiger counter GGreg20_V3 module
09/19/2022 at 16:51 • 0 commentsThanks to our customers, we collected some statistics and received feedback on the different modes of use of our GGreg20_V3 Geiger counter product by users and came to the conclusion that it would be more convenient to fix the voltage in the high-voltage part of the module.
Please note that from September 1, 2022, the function of high voltage regulation has been removed. The voltage level of 400 volts is fixed by hardware means.
This does not change the hardware scheme or functionality of the module. And it only simplifies the initial configuration of the module. From now on, the user does not even need to think about whether the voltage level in the high-voltage part of GGreg20_V3 is set correctly.
At the same time, if you need a module with high voltage regulation for your project, please consider the module DCDC_3V3_400V_V1: High Voltage Module.
Source:
https://iot-devices.com.ua/en/minor_hardware_changes_geiger_counter_ggreg20_v3_en/
Best Regards,
IoT-devices Team
The case 3d-model for the GGreg20_V3 module for personal use
08/19/2022 at 07:09 • 0 commentsIoT-devices, LLC has shared the case a 3D model for the GGreg20_V3 module for personal use by anyone.
You can order such a case as an option together with the GGreg20_V3 module, or you can download and print this model from two parts – top and bottom (you need to download both models).
GGreg20_V3 Case 3d-model source files collection:
https://sketchfab.com/iot-devices/collections/ggreg20_v3-case-d7fb99552f054ad5a7960c43e66bae18
The casing model assumes that JST-type side connectors will be installed on the GGreg20_V3 module board. You can view how the casing looks on the GGreg20_V3 module on the product page on the company’s website and on Tindie .
News Source:
https://iot-devices.com.ua/en/ggreg20v3-case-3d-model-for-personal-use/
Technical note. DIY Geiger counter: GGreg20_V3 and ESP12.OLED connection diagram
08/04/2022 at 14:56 • 0 commentsThis document is for the attention of those users who are going to connect two GGreg20_V3 and ESP12.OLED modules together.
Read Full Text (EN):
https://iot-devices.com.ua/en/diy_geiger_counter_ggreg20_v3_and_esp12-oled_wiring_diagram_en/
Read on Ukraininan:
https://iot-devices.com.ua/diy_geiger_counter_ggreg20_v3_and_esp12-oled_wiring_diagram_uk/
#DIY, #ESP12.OLED_V1, #ESP8266, #GEIGER_COUNTER, #GGREG20_V3, #RADIATION_COUNTER, #SBM20, #UART, #WIRING
How to add the GGreg20_V3 ThingSpeak channel sensor to the Home Assistant server
07/27/2022 at 18:25 • 0 commentsIf you have a controller with a GGreg20_V3 radiation detector module that periodically sends data to the ThingSpeak server, you can also easily connect it to your Home Assistant server as well. In this publication we will look at why this might be necessary and how to do it.
Full Article: https://iot-devices.com.ua/en/how-to-add-the-ggreg20-v3-thingspeak-channel-sensor-to-the-home-assistant-server/
GGreg20_V3 – in the Popular Products section of Tindie Marketplace!
07/13/2022 at 08:00 • 0 commentsThe product of the Ukrainian technology company IoT-devices LLC – the ionizing radiation detector module GGreg20_V3 – was placed in the Popular Products section of the Tindie Marketplace website!
What a week! The IoT-devices LLC team is grateful and thanks the DIY community and customers for choosing and trusting our product!Thank you!
Kyiv. Ukraine. IoT-devices LLC
Source: https://iot-devices.com.ua/en/ggreg20_v3-popular-products-site-tindie-marketplace/
Now you can read "IoT-devices" publications on the Medium platform
06/01/2022 at 20:55 • 0 commentsThe first one story is:
Now you can read "IoT-devices" publications on the Medium platform.https://t.co/xtrhV44Ece
— 🇺🇦 iot-devices.com.ua (@iotdevicescomua) May 31, 2022
