fbus_3310_pinout.jpgF-Bus pinoutJPEG Image - 100.15 kB - 12/21/2021 at 00:20 |
test_3310.pyCommunication testing script, to run it create a python virtual environment and install in pyserial, or just run it if you have already pyserial installed in your main Python3.The script is just to show that the adapter is working, to establish a proper communication the comm. protocol implementation is needed. This will be the next project. x-python - 527.00 bytes - 12/20/2021 at 22:32 |
nokia3310_adapter.stlThe F-Bus pogo pin holes are designed for a 2mm in diameter pin socket and they need to be widened with a 2mm drill bit.The widening is easy and can be done by hand. sla - 274.30 kB - 12/20/2021 at 20:53 |
