IPI-U05 (edited).EQN.txtApplication connector address decoderplain - 2.33 kB - 02/12/2023 at 01:52 |
plain - 766.00 bytes - 02/12/2023 at 01:52 |
IPI-U01 (edited).EQN.txtZ180 glue logicplain - 2.53 kB - 02/12/2023 at 01:52 |
IPI-U04 (edited).EQN.txtSeems to be the STEbus address decoderplain - 3.06 kB - 02/12/2023 at 01:52 |
IPIMON-v1-6_4732-00-asm2 (8).txtIPI Monitor ROM source code partly reverse engineered.plain - 84.22 kB - 02/05/2023 at 14:32 |
IPIMON-v1-6_4732-00.binIPI Monitor ROM as binary file.octet-stream - 5.00 kB - 02/01/2023 at 12:00 |
IPIMON-v1-6_4732-00.hexIPI Monitor ROM as Intel hex file.hex - 13.76 kB - 02/01/2023 at 12:00 |
IPIMON-v1-6_4732-00.hIPI Monitor ROM as C header file.x-chdr - 197.43 kB - 02/01/2023 at 11:57 |
IPI_PAL_files.zipIPI PAL files, JEDEC and disassembled equations.Informative pin names partially established. application/zip - 8.13 kB - 01/04/2022 at 16:31 |
BT IPI in BT Engineering magazine.zipBritish Telecom Engineering magazine mentions their various STEbus boards.Zip Archive - 79.34 kB - 01/04/2022 at 16:42 |
sn74als1035.pdfThe only unusual component, it is a non-inverting open-collector buffer.Adobe Portable Document Format - 1.06 MB - 01/04/2022 at 18:30 |
