Mechanical to Arduino timer/selector conversion
Arduino saves a broken washing machine
Public Chat
After the spring on the mechanical timer decided to come loose and trying to fix it with no success, I decided to replace it with a Arduino controlled relay.
The 2 selector knobs are replaced by one rotary/push switch and a 5110 screen.
Selections are displayed on the screen and can be selected using a rotary push switch.
There are 3 wash type selections, Strong, Normal and Gentle.
The original timer only ran for maximum of 15 minutes, I decided on allowing selecting up to 60 minutes of wash time in 5 minute increments.
As an added bonus I added a soak timer that can be set for up to 10 hours of soak time before the washing cycle starts.
The soak and wash timer are displayed showing time left once the selections are made.
Once the soak and/or wash cycle starts the machine can be reset at any time by a long-press.
The Arduino program uses non blocking timing to run all timers and the wash cycle.
I cut out the place where the 2 selectors were and 3d printed a new front panel.
The back of the panel has standoffs for screws that allow the box with the relay, power supply, Arduino and relays to be mounted.
wasmashien3.stl
Front panel
Standard Tesselated Geometry - 505.65 kB - 01/30/2022 at 09:29
Download
wasmashien-Body003.stl
Parts box
Standard Tesselated Geometry - 6.14 kB - 01/30/2022 at 09:29
Download
wasmashien-Body004.stl
Clip to keep box in place
Standard Tesselated Geometry - 2.23 kB - 01/30/2022 at 09:29
Download
wasmashien-Body002PolarPattern.stl
Lid (fastens to backpanel)
Standard Tesselated Geometry - 114.14 kB - 01/30/2022 at 09:29
Download
washing_machine_prog_1.ino
ino - 8.50 kB - 01/16/2022 at 12:38
Download
  • 1 × Arduino Pro Micro
  • 1 × 30A relay module with 2 relays
  • 1 × 5110 LCD display
  • 1 × Rotary encoder with push button
  • 1 × 220 ohm resistor Connectors and Accessories / Miscellaneous Connectors
View all 8 components
  • Installation
    Setvir • 01/30/2022 at 06:04 • 0 comments
    3d printed front panel and box for the installation.
    Connected the Hi-Link AC-DC Module to mains.
    Tested without connecting motor wires and relays worked as expected.
    Connected motor wires.
    Sealed off cables and front panel with silicone to guard against moisture.
    All was tested and the program worked as expected.
    Machine washing and working again!
    One problem with the 5110 is that it keeps getting darker and after some time unreadable. Tapping the screen clears it and it works normally. I have checked all the wire connections and they are fine.
    I suspect this is due to a dry joint on the 5110 board or faulty LCD.
    But that is a problem for another day! :-)
  • Initial breadboarding and programming.
    Setvir • 01/16/2022 at 12:36 • 0 comments
    All components have been connected using breadboard and jumpers.
    Arduino program has been written and tested. As usual I wrote it to work not to be the best example of programming. :-)
View all 2 project logs
