RJ45_Tester_r1p2.zipLicense and Manufacturing Files (Gerbers and Drill) for the PCB.Copyright (c) 2022, Bob Harbour All rights reserved. Redistribution and use in source and manufacturing file and physical forms, with or without modification, are permitted provided that the following conditions are met: * Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer. * Redistributions in manufacturing file form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution. * Redistributions in physical PCB or finished goods form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution. * Neither the name of Bob Harbour nor the names of its contributors may be Zip Archive - 7.35 kB - 03/01/2022 at 15:12 |
Bill of Materials-RJ45_Tester.csvBill of Materials for the boards. You can skip ordering resistors and a battery holder for the Receiver board.Comma-Separated Values - 660.00 bytes - 01/24/2022 at 17:14 |
