Hackaday.io Hackaday.io
Sign up Log in
A Portable White Noise Generator Circuit
hesammoshirihesam.moshiri
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
2 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
593
0
2
1
Team (1)
  • hesammoshirihesam.moshiri
Join this project's team
  • Altium Designer + License (Free)
completed project
hardware
white noise white noise generator random noise generator noise generator circuit
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 01/28/2022 and last updated 4 years ago.
Description
The white noise generator circuit is a handy tool that can be used to examine the circuit or a communication line under some random noises to make sure about the stability of the device in real and harsh environments. The current consumption of the device is low, so you can power the circuit using a small 12V-23A battery. if you have access to a 3D printer, you can build a nice enclosure for the circuit. The schematic and PCB have been designed using Altium Designer 22. The output white noise has been tested using the Siglent SDS2102X Plus oscilloscope.
Details
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
We will build a hardware prototype of the amplifier and test its performance
Project Owner Contributor
How to Build a High-Efficiency Class D Audio Ampli
avaq-semiAVAQ SEMI
Feel the extraordinary bass of this amplifier, Hi-fi and realistic audio using TDA7294 Mono.
100Watt Audio Amplifier using TDA7294
sagar-001Sagar 001
This is the best hack to do with your siblings when watching tv without your permissions. Informative tech about IR receiver jamming
IR Jammer circuit using NE555 timer
lithium-ionLithium ION
To build a complex circuit using many components.
MEGA CIRCUIT
adesh-manhar-ramkissoonadesh manhar ramkissoon
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "A Portable White Noise Generator Circuit", please tell us the reason.
Send message
Remove Member
