I made a tool that converts an image into multiple PCB layers - pixel brightness to board opacity. (for use with Eagle)
or: How I Learned to Stop Worrying and Love the Board
Alon Gruss 20/11/16
Tl;dr:
1. You are not limited to your discipline!
As a Designer by trade I like to jump head-first into new disciplines which I know nothing about, learn to control the terminology and try to mess around in unexpected ways. I am also lucky to share studio space with Arkadi Rafalovich, A talented engineer and omni-potentialite, who inspires and guides me through learning the basics of electronics and Eagle PCB design.
While diving into the subject I was constantly visualizing and thinking about the tools that are missing for me, the tools I need for implementing my art and design.
(I recommend Sparkfun’s tutorials).
2. Most PCB’s are boring!
PCB’s are usually designed functionally without any visual attention, A very boring rectangle. Sure, they have their digital charm with mazes of tracing running along the board, but as a user, I prefer my PCB’s when they're inside my products. Covered in a well designed injection-moulded shell.
I use the word ‘usually’ because sometimes you get boards like the Defcon badge - which can masterfully merge function and design to create a fun user experience.
Or this wonderful PCB-USB-Business card by Frank Zhao.
3. The Artist in the Engineer
So, what’s different in business cards and convention badges? These are where the engineer isn't working for a client, he relaxes a bit and has fun with the design tools. He’s not just a cog in the product development process. When he has no restrictions.
Sadly, even then, the board designer dare only to use the tools given. Drawing only in the ‘Silk’/’Copper’ layers or slightly shaping the board’s outline in the ‘Dimension’ layer.
4. All the layers!
Some of my past Design projects deal with layered/laminated materials and the smart use of the different layer properties:
Those were opaque materials. What intrigued me with PCB design-wise, was the ability to play with material’s opacity and the light transfer through the board. Artistically I thought I can convey a more complete message and user experience by having graphics that support and integrate with the board’s functionality.
5. Testing the hypothesis
I searched google for leonardo da vinci’s portrait of Mona Lisa (which I consider globally identifiable) and saved one of the results to my PC.
Opened it up in Gimp. scaled it down (nearest neighbour) and duplicated it to a couple of layers.
I then run a threshold filter on the layers changing the value a bit in each one and saved the layers to separate files.
Only then have I noticed that the new versions of Eagle already have a built-in script for importing image, from colors to layers. “That’s great! This saves me a lot of time” or so I thought.
Don’t misunderstand, It's a really great tool, just not for my purposes.
You see, I need to control the cumulative combination of layer opacities in order to achieve my goal. I aim for the PCB to be facing up (showing the top layers).
For example:
We also have:
You might have noticed that some layers control the lack of material and must be treated as a negative. That’s a bit confusing, so here is a guide table:
( legend: x = no || ⎷ = yes || ? = doesn't matter || n = inverted ) |
Color (layer No.) | Top (1) | Bottom (16) | tStop (29) | bStop (23) | tPlace (21) | bPlace (22) |
0 | x | x | ⎷n | ⎷n | x | x |
1 | x | x | x | ⎷n | x | x |
2 | ⎷ | ? | x | ? | x | ? |
3 | x | x | x | x | x | x |
4 | x | x | x | x | x | ⎷ |
5 | x | ⎷ | x | x | x | x |
6 | x | ? | x | ? | ⎷ | ? |
7 | ⎷ | ? | ⎷ | ? | x | ? |
6. Lessons learned
I ordered the boards from Seeed...
Thanks, I'll check it out!
Neon22- I'm aiming for a standalone app, in "java", that converts raster images to layers in Eagle .brd files. So you can see how an Inkscape extension in python is a bit out of my scope at the moment. I am however planning to integrate .svg vector files.
yeah - it would be really great if you coudl add an inkscape extension (python mostly) that did this and integrated it with Saar's work... Happy to help out with inkscape extensions - I've made a few
Check out PCBmodE.
It's basically a tool that allows you to jump back and forth between a rudimentary script and Inkscape, and then finally exporting the gerbers. Many of the boards created in it are exactly what you're talking about - art pieces first, and possibly functioning PCBs second.
