RP2040 Stamp
A hand-solderable SMD/TH module w/ RP2040 MCU+8MB FLASH, LDO, LiPo charger, reset btn, and Neopixel. Breaks out all GPIO+USB+SWD+BOOTSEL+RST
The RP2040 Stamp is a hand-solderable SMD/TH module that integrates the Raspberry Pi RP2040 MCU with 8MB of FLASH, an LDO, LiPo charge management (including a charge LED), a reset button, and a Neopixel. It breaks out all the GPIOs as well as USB, SWD, BOOTSEL, RST, and the voltage pins. At only 1 by 1 inch (25mm x 25mm), the Stamp packs a lot of features: - 8MB of FLASH - 500mA 3.3V LDO - All 30 GPIOs broken out - A Neopixel - LiPo supply and charging circuit (with charging LED) - USB broken out - SWD broken out - Reset Button - 12MHz crystal
davedarko wrote 03/28/2022 at 12:33 point
since twitter is down
https://hackaday.com/2022/03/28/putting-the-rp2040-on-a-stamp/
deʃhipu wrote 03/28/2022 at 12:38 point
twitter is down?
davedarko wrote 03/28/2022 at 16:17 point
was a bit, I was not alone :D
marcin.puch wrote 03/11/2022 at 14:12 point
Hi. Are you planning to add RAM to this project?
Martin Cejp wrote 01/30/2022 at 21:12 point
Omg, this is adorable, and very useful.
davedarko wrote 01/30/2022 at 20:15 point
such soon, much now
arturo182 wrote 01/30/2022 at 22:24 point
I figured if I have HaD in my twitter bio, I should post this here 😅
