CheatCaseWood.epsBox for the Arduino, LCD screen and buttonsx-eps - 9.98 kB - 11/25/2016 at 09:09 |
PlexiCover.cdrPlexiglass box for the tupe holdercorel-draw - 19.90 kB - 11/25/2016 at 09:09 |
CheatAlimWood.epsBox for the power supplyx-eps - 12.09 kB - 11/25/2016 at 09:09 |
codefinal.inoThis is the code we used for our final draft, which worked perfectly. Before the weldering, when the LCD stopped displaying. We are currently investigating why. But we can't guarantee the proper functionment of this code, even if we believe that it's more a hardware/connectivity problem.x-arduino - 2.68 kB - 11/25/2016 at 07:59 |
codeWithoutLCD.inoThis is the Arduino code we used when our LCD died, which can happen to anyone. So use that if you don't have a LCD displayer, use this code and display the rpm and time configuration on your PC.x-arduino - 2.07 kB - 11/25/2016 at 07:56 |
