How hard could it be to build a standing desk? Well the answer is that it is not easy.
I wanted a desk which was 2.2m long and built from mild steel and dark wood. Naturally this would end up being a heavy desk. 100Kgs by the end of the day.
The desk is controlled by an ESP32 which hosts a VUE web app (Squeezing this onto the < 2MB of flash was a real mission). I used an accelerometer to calculate the desk's lean/tilt and used these values to perform safety checks during operation. The height is measured with a TOF sensor and the motors were supposed to be controlled my an H-Bridge, but I didn't read the user manual. As such I found out a bit late that the H-Bridge has an internal 2V voltage drop, so I rigged a 4 channel relay into a hacky H-Bridge. The 4 Channel relay was supposed to be used with electro magnets for stability but it ended up not being necessary.
