[P]
A project log for SecSavr Sublime [gd0036]
An FDM 3D printer that I described as "The FULL Coverage, Extended X, Pro Max, Ultramatrix Solution".
kelvinakelvinA 03/11/2022 at 16:540 Comments
M8 Zinc Bolts and self locking nuts
My order of 150 nuts and bolts have arrived. I tried to find bolts that used allen keys, but they were drastically more expensive. Instead, I looked for bolts that were only partially threaded, which should give more usable life than if the bearings were pressing on threads.
[first bolts I bought on left, new in centre, bearing location on the screw is simulated on the right]
