This printer has a 700mm Z height, and I don't remember the XY but it should be around 200mm. It's a CoreXY and uses dual 6028 blower fans for printing thick layers in PLA and 2 5kg weights in the base. It's designed to fit in the build volume of a CR10.
kelvinA
