Little Frankenstein
A project log for DJI FPV - Battery Breakout Mod [1]: First Tests
I'm trying to mod/recreate the DJI FPV battery to use regular 6S lipo batteries. In a first attempt I try to replace the lipo cells.
aircruiserAirCruiser 05/04/2022 at 16:536 Comments
Just a quick update
I soldered all the components of my first test onto a perfboard. The display shows the voltage [V] and the current [mA]. Instead of the percentage, the glasses show the voltage (10x). Big and ugly, but it does the job. After some more tests and improvements I will design a PCB.
Vedmant wrote 08/06/2023 at 13:58 point
Hey, nice work, maybe you can help, I have battery communication error after minor crash on the battery. It looks like battery locks out itself, is there any way to unlock the battery?
Klaus Wald wrote 05/11/2022 at 07:35 point
simply a top work, I'm looking forward to further results.
ChangeTsai wrote 05/06/2022 at 16:45 point
What an amazing work!
ChangeTsai wrote 05/06/2022 at 16:41 point
how to do it?
AirCruiser wrote 05/27/2022 at 21:43 point
Sorry for the late reply. I'm trying to write everything down but it's taking a while and there are loads of other things to do at the moment. But there will be detailed instructions :)
nguyenmihung wrote 04/20/2024 at 07:50 point
Hopefully your detailed instructions will be issued soon. Or you can make a video describing in detail the DJI FPV battery mod, everyone will enthusiastically receive it.
