tardis_network.hcode for using WiFi shield to trigger actionsh - 7.91 kB - 04/20/2022 at 09:19 |
ArduinoTARDIS.inomain program - initializes stuff and starts everything upino - 8.64 kB - 04/20/2022 at 09:19 |
RGB_Pulser.hExtends Pulser class to work on three LEDs grouped togetherh - 2.31 kB - 04/20/2022 at 09:19 |
example_network_config.hcustomize network settings for your Wifi access and adafruit settings.h - 451.00 bytes - 04/20/2022 at 09:19 |
tardis_audio.hUses Robertson WAVE shield from Adafruit to play wave files.h - 4.20 kB - 04/20/2022 at 09:19 |
Flasher.hDefine API to control an LED.h - 3.19 kB - 04/20/2022 at 09:19 |
Pulser.hExtends Flasher to create the visually pleasing brightening and dimming of an LED using the Flasher class.h - 3.49 kB - 04/20/2022 at 09:19 |
ir_decoder.hStart at decoding IR signal.h - 932.00 bytes - 04/20/2022 at 09:19 |
atx_shield.hCode for controlling the ATX shield from Sparkfun. Standby power is used to power the Arduino, control ATX power to drive 6 LED PWM channels.h - 1.23 kB - 04/20/2022 at 09:19 |
