Going to the extreme to save a PCB for no reason!
I was given this game to repair and was shocked to find that every via on the PCB was destroyed. Time to order a new PCB for 12 bucks. Or...
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This game did not boot and its clear why. Every via has seen water damage which broke all of them. Obviously the "best" course of action for a PCB this badly damaged is to just replace it. BUT... I wanted to explore the extreme option of repairing every damaged via to get it working again.
I removed the soldermask of the PCB using sandpaper to expose the copper that will be used for soldering. From there I threaded 30 gauge wire through every via so that it could be used to fix the connection between the top and bottom layers.
After everything was soldered I applied a heavy coat of conformal coating to protect all the jumper wires and the exposed copper.
This was complete overkill for the love of overkill and I really love the results. So much that I plan on buying this a clear case to better display the work.
Check out the video for every bit of detail :)
