1Cutting the pipe to size
First cut the pipe to the appropriate tunnel size
2Cut the box into a mountain
Cut a box into a tunnel for the mine
3Glue the tunnel into place
Next get the glue gun and glue the PVC that you made before around the track
4Glue another pipe down
cut a nuther pipe then gule it down
5Glue the mine/mountain down
now gule the mine down on top of the small pipe
6Put the aluminium foil on the big pipe
Now get the glue gun and glue the foil down on top of the big pipe
7Put more alluminium foil on the pipe
Put more aluminium foil on the other side of the big pipe
8Pick up some rocks
Take your little sister to a local park and get some rocks
9Start the mashe
Now dip newspaper into the paper mashe mixture and then put it on the mine. If you want it with a tip you can cut up more cardboard and then do lots of layers on it.
Do lots of layers. The more the better.
10Paint the rocks
Mix red, silver glitter and purple till you get a mars colour. My sister also helped with the painting
