The new mount plate comes with various improvements. The rolls are now mounted with 3mm screws instead of the previous 3d printed parts and no nuts are used. They also have now handles so its easier to lift them up when loading a film.
The roll that detects the status of the winded up part of the film can now be moved in a larger angle and also has a handle.
The rolls themselves have a clear position for the bearings. The film clearer is more robust than the previous version. I printed the plate itself in PETG, the movable parts in PLA. All with a 0.4mm nozzle, so it should be easy for everyone to print.
Anton
Cadmium
Andy from Workshopshed
Logan Fouts
Very interested in the V2, Will the PCB files be available ?
