Energy Independence While Travelling
Bring your own clean power.
Pack a Kite Turbine in your EV
Public Chat
Build a flying wind turbine for energy independent adventures.
Let's add portable kite power to your e-bike or e-car.
Harvest clean power on your adventure.
Kite Turbine - Basics.
Wind lifts, inflates and spins a network of kites for energy output.
Kite Turbine - How / Why?
Tensile structures are lightweight (materials align with forces)
The lightweight blades sweep a large area as an auto-gyro wind turbine.
Kites and rotors can stack and pack in modular network patterns for scaling.
Light and fast = efficient harvesting
Investigation into this method is ongoing and intended to addresses the carbon intensity of large wind turbines at scale.
WARNING ! Experimental prototypes!!
Consider Safety.
Carelessness kills!! Kites are powerful!!
We are automating for safety. Our new 10kW system will remove the need for a human operator.
Do not build a simple Kite Turbine larger than the >1kW capable one we show
Planet-Friendly Power
CC-BY-SA-4.0
How to make an energy independent electric vehicle with a Kite Turbine.
Instructions
  1. Put a Kite Turbine in your car
  2. Park up (best on a windy hill)
  3. Fly the Kite Turbine
  4. Use it to charge the EV battery
Well sort of, yes.
We've flown a bunch of missions and made lots of power, done some car charging and made lots of tea in the field. Lovely.  But as you'd expect with wind power, and especially with freaky flying wind power, it's a lot more complicated than that.
I started testing ideas on kite power in 2010, because kites can provide a lot of power with little material. Also the sky is bigger than a wind turbine and there's more power higher up.
Harnessing kite power and converting it to electrical energy - can't be too hard ! And it's a really good thing to achieve because it could be scalable.
Most Airborne Wind Energy Engineers start out like this, and also from being Kite Surfers.
After a lot of experimenting, My favourite method is the Kite Turbine.
It's simple, continuous rotary output, scalable yet workable on a small scale, mechanically autonomous (apart from launch & Land & as long as it's all balanced)
You can see the launching process sped up in this video
First of all the lifting kite is launched. It's job is to guide the turbine downwind, and give initial line tension to hoist the turbine.
The turbine is then released into the air using the back-line to hold it down.
The brake is released on the ground station so that rotation can start and regen can begin.
If you're going to build one consider this requirement set as a minimum
I'm going to add a few more IMU attitude and RTK GOS sensors to mine soon ... but don't worry about that yet.
The wise among you might now be thinking... That's bizarre - torque - sent along a string  - but surely it would just over-twist?
And yes - without line tension (kites) and the extra rings between the lines- it would twist and has sometimes over-twisted in the field. The power transmission here is rotary. That's novel, but it works. We use normal Dyneema(R) rope tethers.
But How? This is where researching Tensile Rotary Power Transmission (TRPT) will help.
I'd recommend Oliver Tulloch's PhD and the Airborne Wind Energy Forum
TRPT works with 2 ratios, the geometry ratio (ring separation / ring diameter)  and the force ratio (Axial tension / torque) . For a given geometry ratio you can safely apply a certain force ratio by adjusting the torque demand at the generator. Balance these and it works.  More pull axially means a more torsionally rigid shaft = higher energy transfer capacity.
For your TRPT build... Have you considered all of these parts
Now we have that tensile shaft power down on the ground we can plug it into a Power Take Off Wheel on an anchored ground generation station.
Notice that there are 2 sticks at the back of this ground station generator... Without them it get's wobbly.
This was a ground station and turbine combo I was preparing for the scouts (More about that at the bottom of this chat.
The ground station has to have a really good anchor. You never want to see a 20kg lump of edgy steel flung past your head by an angry kite.
For ground station designs go here ground stations
Consider this as your minimum requirement set to build this one
Going to have more sensors again on the next one.
The ground station motor/generator controller code can be found here DaisyKiteTurbineControl
it controls this rats nest
A lot more on making and operating Ground Stations in this video
With the software and knobs and sensors, You can govern the max regen and mix the levels of control from the tip speed ratio, the tension torque ratio and the speed trend. You can also hold a brake and boost forward for start up or unwinding a mistake.
You could be more thorough and structured using requirements...
Kite Turbine for CFD.igs
A model of the 1kW turbine being developed for CFD analysis
Initial Graphics Exchange Specification (IGES) - 15.60 MB - 08/21/2022 at 11:03
Download
CFD 1kW model.3dm
A Rhino 3d model of the turbine being developed for CFD analysis. Use alongside the .gh grasshopper file
3dm - 3.69 MB - 08/21/2022 at 11:03
Download
parts for CFD.gh
the grasshopper description of the turbine for CFD
gh - 2.05 MB - 08/21/2022 at 11:03
Download
Line Lengths on Standard TRPT 1kW.xlsx
Line lengths and diameters on the TRPT and turbine
sheet - 7.37 kB - 08/21/2022 at 11:03
Download
sub 1kW Kite Turbine Parts Descriptions.pdf
The bits you need to put together and what they do
Adobe Portable Document Format - 779.25 kB - 05/02/2022 at 10:29
Preview
  • 1 × VESC6 The VESC (Vedder Electronic Speed Controller) will save you grief. It's an amazing motor controller. pricey though.
  • 1 × E Bike Wheel If you get a direct drive motor with a wheel and rim for the PTO that's easiest. If you get a gearedhub motor you have to make sure you are running the motor the right way and the wiring is coming out the correct side or you can weld the clutch on the planetary gear ... see my youtube on that
  • 1 × e-bike motor cable standard connector often Julet Keep your cabling tidy and connectors dry
  • 12 × 2m x 5mm GRP or Carbon epoxy rod lengths to make the torque tube and top support rings You will need varying lengths of this for different rings ~12 x 2m
  • 1 × Dacron Tape for leading edges, line tapers, webbing, seams, joins, ring cuffs, anything sew-y
View all 27 components
  • Why Develop Kite Turbines?
    Roddy "Rags" Read10/22/2022 at 10:14 0 comments
    The quick answer - Clean, cheap, abundant energy
  • Sims
    Roddy "Rags" Read06/03/2022 at 08:46 0 comments
    Got a couple of sims for you
    A view of our long term ambition - a network of networks, Kite Turbine field layout
    Rough animation of a Backline handling Bot to improve ease of deployment and safety
    Using a Backline Bot will likely be our standard method for single turbine releases on flat enough ground till maybe 100 ~200 kW
    After that  - inside the net of nets (as above) deployment from the ground station will be better...
    Might look like this
    For a tilting carousel like this which releases the rotors and transmission lines and rings - We'll want the rotors to be able to expand in tension once spinning.
  • Your Motivation - Why Kite Turbines Matter
    Roddy "Rags" Read04/28/2022 at 20:58 0 comments
    This is why - We all want a future with Abundant Clean Energy
    Kite Turbine power is scalable using lightweight tensile networks.
    Higher altitude wind is more energy dense and these kite turbines are very light in embodied CO2e   So if we can make these turbines reliable (already mechanically autonomous)   They could change the game on cheap and clean energy farming.
    So
    More Detailed Instructions
    1. Make a Lifting Kite
    2. Make a Kite Turbine
    3. Make a Ground Station
    4. Put it all in your car
    5. Park up (best on a windy hill)
    6. Fly the Kite Turbine
    7. Use it to charge the EV battery
    First though We're going to talk about your motivation (Is that something actors do?)
    Motivation Instructions
    Build a Kite Turbine
    Simple as that. It's fun, It's got power comes out. Not only that ... You might be doing a really good thing.
    We build Kite Turbines because the world needs clean affordable energy.
    We all know wind turbines are amazing right.
    Yes - but no. They're so heavy they can't scale.
    Wind power is not yet as amazing as it's going to become.
    Looking down on wind turbines from an airplane, you realise, they are tiny compared to the airspace they could be extracting from, and that airspace has more powerful and consistent wind away from the surface.
    A Network of kites high above a wind turbine farm
    Here's why Wind turbines aren't as high as kites yet.  They're seriously heavy. See this IRENA graphic.
    Wind turbine towers are massive rigid steel structures. Strong enough to resist the cantilever bending, head mass loading and generation torque. These towers have to follow cubic mass scaling (To the power of ~2.63)
    Onshore, the tower is fixed to a huge concrete foundation to prevent it toppling over.
    A road has to be built up a hill. Giant blades have to be made so that the tips (the efficient part) can sweep further at high speed.
    This is not an efficient design yet. Material is not aligned with the force.
    Like a suspension bridge, Kite Turbines use efficient design to align the loads (blade aerodynamic forces) with efficient tensioned lines.
    Kite Turbines don't need the tower, the foundation, or the road.
    Even most of the blade is cut from a Kite Turbine. These blades only fly the outermost ring. The most efficient part.
    Generic Kite Turbine design
    Generic 3 layer x 5 blade rotors Kite Turbine design, Let's say ~ 10kW
    The power to weight ratio of standard wind turbines is dreadful, which means it takes them longer to pay back the carbon equivalent emissions embodied in their manufacture.  Endurance E3120 50kW = power-to-weight ratio of only 0.02kW/kg (And that's a good one it's only wee)
    Kite Turbines Power-to-Weight tested 1kW/kg (Airborne) 0.2kW/kg (total)
    You've seen how basic our Kite Turbines were... We are quite certain we can increase this to >2kW/kg (airborne)  >.8kW/kg (total)
    When I walk up to a wind farm, Standing right up underneath a giant wind turbine, I look at the stairs leading to the tower access door. I estimate the mass of just the handrail (not the balusters) is the same mass as an entire >3kW Kite Turbine.
    That 3kW is a magic number... Your modern kettle is up to 3kW.  3kW is ~ the average (24/7) power demand of a UK home. It's also the speed your domestic plug will charge an EV car. And this Kite turbine fits in the back of your car ... oh
    Here's the thing, this could be BIG
    We suspect kite turbines are going to be very scalable
    Eventually with more research - The forces in a network of network turbines should look something like this
    And we're going to assess how offshore capable they are.
    There are further positive effects of designing wind turbines (Kite Turbines) this way. The modular blade elements can all be swapped out very quickly on the ground (no crane or rope access experts needed) ...
View all 3 project logs
  • 1
    Read up
    First off, before building, make sure you have a good clear understanding of what you want to build.
    The scale and complexity of a kite turbine project is a large undertaking for a home project.
    Check the files section and read the  - sub 1kW Kite Turbine Parts Description document to get a clearer idea of what you could build.
    I don't recommend going straight to the scale of 1kW - That in itself can be a dangerously powerful kite machine.
    Please feel free to adapt this. However-
    This project is CC-BY-SA-4.0 as long as you keep it under 1kW.
    None of this work is for Kite Turbines in excess of 1kW
    We will be attempting automated control of larger Kite turbines at W&I only when we remove all human operations from the field of work.
    Thank You for reading that warning list so carefully
  • 2
    Lift kite
    Let's start at the top with the lift kite
    An HQ KAP foil lift kite is a good steady lifter ... not so strong pulling as a single skin but stable.
    Practice with these so you are comfortable with their use before you attach one to a turbine.
    Make sure it is pulling >10kg on the line before you attach it to the lift line bearing at the top of the turbine. You are likely to a couple sizes from 3 to 6m.
    Here's how they handle in extreme turbulence with a variety of bridle, tether and tail modifications
    Making a controller for these lift kites is easy enough with radio control and a servo pulling the B2 steering lines  ... This will allow you to pull the turbine to the side and stall it without using a backline.
    Adding an arduino and an IMU is bonus - Some simple proportional code https://github.com/rodread/lift-kite-controller
    Here's a description of how that went on the AWES forum
    https://forum.awesystems.info/t/building-a-rc-pilot-kite/524/18
    I used to use 3 lines on the lift kite. The main tether to the turbine head and 2 steering lines to downwind anchors. This however does not let you weathercock the whole set so only do this if your wind is always in a steady direction
    Some old Daisy Kite turbine launching videos
  • 3
    Making Kite Turbines 2 different ways
    Now for the turbine
    First up is the older Ram Air Kite Turbine Way
    I published the detail for that on Hackaday a few years back https://hackaday.io/project/159049-portable-kite-turbines/log/149130-oh-yeah-the-kites   Gave that hack a big update yesterday
    This is how the turbine for the scouts went together
    Right now for the 2nd version using rigid blades
    ...  This makes a much faster and more efficient turbine
    A single rotor element now looks ~like this
    A NACA4412 foil cut from foam, built like a model airplane wing, at 20cm cord ~1m span. Made from 2 parts 1 at 70cm span and one at 30cm pan. The 2 spans are covered in shrink film. The 2 spans plug into the fuselage.
    The fuselage joins the blade to the main ring compression cuff. (a tube of dacron tape 340cm long with a web strap at one end and a web strap clamp at the other)
    2x 170cm carbon rods go in the main ring compression cuff (forward of the wing)
    4 bridles hold the blade to the main tether. Bridles bank the blade with outer tip slightly pointed down (This directs lift away from the axis and helps rotor expansion against torsion.. Helps for stacking rotors.)
    An stl of the fuselage is in the github links https://github.com/rodread/DaisyKiteTurbineControl (often appears 10x too small on 3d print slicing software - comes from rhino working in mm not cm)
    The 70cm and 30cm span blades are hot wire cut foam, with shrink bonded tape covering. Then plugged into the fuselage cuffs. Then duct taped to the cuffs.
    The shrink wrapped blades are slotted into the cuffs of this fuselage .
    The spars tubes run through inside the blades and through the fuselage the whole length of the span. The bridles tie around the spars.
    A line looped through both of the spar tubes holds them into the foam, preventing them from being flung out by centrifuge. (That has happened. Do avoid throwing spears around your field)
    There's 4 wee spreaders (made from ~2cm lengths of rod) to stop the bridles cutting into the wing and spars. A loop on the bridles goes over these bars. The bridles all come out on the other side and tie onto the main tether. Best to set the bridle lengths so that the blades outer tips are closer tot the ground than the inner tips. Helps with aerodynamics and dynamic ring expansion.
    Put 2 of the 170cm rods in the sleeve, attach the sleeve to the next sleeve, repeat until you have (6 in this case) in a rotor.
    Here is a dimensioning guide for Kite Turbines
    For your blade tethers, tension them all with the same weight and mark them to make sure they're all the same length with a figure 8 on the bight tied in the end ready to connect to the tether at the top end of the transmission.
    Figure 8 on a bight is easy to turn into a larks head knot to connect over another figure 8 on a bight.
    Super simple way to make the system modular. so you can attach new transmission or elements as you like.
    For our next set of wings I'm leaning toward ...a mix of cut/print wing rib with foam inserts, a printed fuselage as before, all slotting on together with carbon spars, tied through and end capped ... and also I think a vacuum carbon epoxy skin might work nicely. If you make wings... please get in touch.
    Also for getting more blade performance data to the generation control . I've re-worked the amazing D-Rhem VTOL flight controller to get rotational position dat from the rotors with an ESP32 and MPU9250 https://github.com/rodread/dRehmFlight/tree/master/Versions/dRehmKITE_rod_ESP_wifi-mpu9250SPI
View all 10 instructions
kateangila67672 wrote 07/15/2023 at 06:00 point
Very cool project. You did a great job I want to implement this on my web page, You can see here:  https://thetravellino.com/faisal-movers-karachi/
albertgiorgia1 wrote 05/31/2023 at 02:54 point
You have put great effort into the project. It will surely help people for long travels.
https://nolcard.ae/
hannahgarner823 wrote 10/04/2022 at 10:15 point
Awesome project! Many individuals were made aware of the limited nature of life and the vastness of the earth by the epidemic. Given that they have first-hand experience with how rapidly life can be changed, individuals are increasingly seeking out high-end, luxurious trips, according to the tourism industry. I then came upon https://danitravelswell.com/ They ask me to complete their questionnaire as the first step toward the holiday I desire and need as they are the top luxury vacation planners.
Roddy "Rags" Read wrote 06/03/2022 at 08:39 point
Another view of our long term ambition - a network of networks, Kite Turbine field layout
https://youtu.be/LbzBQRRHago
Roddy "Rags" Read wrote 05/24/2022 at 11:41 point
Yay, We got through round 1 of the prize!!! Wooop Thanks!
Here's a simulation I made of the long term goal
https://youtu.be/5eUDLZy5hmw
Jacob wrote 05/03/2022 at 15:09 point
Very cool project!
