Body1.stl
Original file from pashiran: https://www.instructables.com/Motorizing-an-IKEA-SKARSTA-Table/
This will be screwed into the table and the case comes on top of it. Some M3 insert nuts need to be soldered into the filament.
Standard Tesselated Geometry - 323.52 kB - 06/12/2022 at 18:13
Download
ideaMaker_print_settings.bin
Print settings template for the ideaMaker slicer.
octet-stream - 23.98 kB - 06/12/2022 at 18:11
Download
case_with_HC-SR04_holes_.stl
Case (top part) for the electronics. Has two holes for the ultrasonic sensor.
I printed with 5% infill, 0.3 mm layer height, 1.4 shells, print speed 80 mm/s.
This print took 7 hours and 24 minutes.
Standard Tesselated Geometry - 212.68 kB - 06/12/2022 at 18:06
Download
