1Remove the speaker covers and remove screws
Remove the speaker covers (they are just glued) and the top rubber caps and then remove the underneath screws.
2Open the round case
Open the round case with a credit card, your nails or just something soft to avoid damaging the case
3Remove the PCB screws
Remove the screws, but don't remove the PCB from where it's sitting, we just need to lift it a little bit from the left to put our PCB bellow.
4Remove some resistors / bridges
Remove the components highlighted in yellow.
The connection points for the mod are highlighted in red -
5Prepare the PCB with the microcontroller.
Prepare a PCB with the following wiring.The pinout is compatible with microchip ICSP, so, it can be flashed even after soldering.
6Solder the wiring
Solder the wires to the PSONE PCB.
3V
GND
CSYNC (microcontroller input for detecting the type of signal)
PAL / NOT_NTSC (output to select the timing)
And solder the female header on the other side.
I just left 2 spare wires for future uses.
(The rigid wire at the left was just for testing purposes)
7Flash the microcontroller
Flash the microcontroller with the provided hex file.
8Fit it all together
Put the PCB bellow as shown:
With this orientation, you will see that there is no need for insulation, but feel free to add some insulating tape or heat-shrink tube to the PCB.
Now you can tighten the four screws to secure the PSONE PCB.
9Route the wires test and close.
Route the wires as shown and you should be able to put the case back without forcing anything.
10End result
This is the expected result:PAL boot screen:
NTSC game:
