slot-plate.stlPlate that affords adjustable column stagger and splay via slots for M3 bolts.Standard Tesselated Geometry - 1.89 MB - 06/27/2022 at 23:14 |
thumb-cluster.stlThumb cluster switch housingStandard Tesselated Geometry - 438.85 kB - 06/27/2022 at 23:14 |
finger-column-single.stlKeywell for a single finger column of switchesStandard Tesselated Geometry - 591.20 kB - 06/27/2022 at 23:14 |
post-hex-m3-25mm.stlPost providing adjustable height for 25mmStandard Tesselated Geometry - 11.21 kB - 06/27/2022 at 23:14 |
finger-column-double.stlKeywell for a double column of switches (index finger or pinky typically)Standard Tesselated Geometry - 178.21 kB - 06/27/2022 at 23:14 |
post-ring-29mm.stl29mm post for pinky fingerStandard Tesselated Geometry - 11.21 kB - 06/27/2022 at 23:14 |
post-pinky-42mm.stl42mm post for pinky fingerStandard Tesselated Geometry - 11.21 kB - 06/27/2022 at 23:14 |
brain-box-v2.stlCase for Elite-C MCU, RJ9 jack, and reset button plus slack wiringStandard Tesselated Geometry - 326.74 kB - 06/27/2022 at 23:14 |
m3-washer.stlWashers for bolted connectionsStandard Tesselated Geometry - 17.07 kB - 06/27/2022 at 23:14 |
Standard Tesselated Geometry - 328.60 kB - 06/27/2022 at 23:14 |
post-thumb.stlPost to mount the thumb cluster to the slot plateStandard Tesselated Geometry - 102.82 kB - 06/27/2022 at 23:14 |
bottom-box.stlBox for under the slot plateStandard Tesselated Geometry - 331.92 kB - 06/27/2022 at 23:14 |
Standard Tesselated Geometry - 293.25 kB - 06/27/2022 at 23:14 |
elite-c-case.stlHousing for the Elite-C microcontrollerStandard Tesselated Geometry - 9.85 kB - 06/27/2022 at 23:14 |
