Mega Charger
Bulk charge 12 USB battery banks at once
I have 12 LED strips around a trampoline each individually controlled. Each also has a battery bank to keep it running. These 12 batteries need charging just about simultaneously and hogging all the phone chargers in the house was becoming a bit of a hassle. I pulled an old PC power supply out which has more than enough current to charge the batteries and made a funky battery holder unit for the power banks to sit in while charging. All the batteries charge quickly and at the same time. The ammeter on the front lets me know when everything is charged up.
This project uses a ATX power supply, these supply a significant amount of current compared to a phone charger.
Power is delivered to each connect via copper wire strips and low-cost micro USB cables.
The result is a funky-looking functional battery charger.
batteryHolder.stl
Mount to hold batteries
Standard Tesselated Geometry - 984.94 kB - 07/07/2022 at 22:56
Download
rearSupport.stl
Rear support
Standard Tesselated Geometry - 875.94 kB - 07/07/2022 at 22:56
Download
FrontDisplayHolder.stl
Front display mount
Standard Tesselated Geometry - 501.60 kB - 07/07/2022 at 22:56
Download
top.svg
Outline for acrylic
svg+xml - 13.01 kB - 07/07/2022 at 22:56
Preview
  • 1 × Voltmeter/Ammeter
  • 12 × Micro USB charging cables
  • 1 × Fuse holder
  • 2 × Input terminals
  • 12 × Battery case https://www.aliexpress.com/item/1005001703354315.html
View all 7 components
  • 1
    Print STLs
    These should be pretty straightforward to print. No supports and 20% infill. For the screw holes, I like to add a support blocker (Cura) and increase the wall count to 6 to make sure these holes are solid. This prevents the screws from splitting the PLA.
  • 2
    Top and bottom acrylic/wood
    I printed the SVGs to the correct size glued these onto the top of the acrylic and used this as a template to cut out and drill. This is easy for acrylic as it has a protective sheet to peel off any. Wood might leave a mess.
  • 3
    Hook up wiring
    Check the gallery for the wiring diagram. These meters have a weird sort of configuration with the wire colour and you need to connect a red wire to the negative side which doesn't make much sense but hopefully, the picture will help.
View all 4 instructions
