If Otter falls and hits the top of his head, it can damage his brain, even be fatal; so we're trying to keep this area soft,padded,and safe.
FoamHeadBandOutline09_22.pdfhere is the updated Wire Loop versionAdobe Portable Document Format - 10.13 kB - 09/23/2022 at 20:56 |
FoamHeadBandOutline08_22.pdfThis is the current profile that seems to be the best fit. It is the Foam Band and Plastic Cut-out profileAdobe Portable Document Format - 6.06 kB - 08/10/2022 at 22:59 |
Otter had his surgery to close the hole in his skull in Dec 2022; his recovery went extremely well and has been back to being an incredible kitten - he'll have the opportunity to grow up to be a healthy loving creature!
This is a jig for the laser cutter.
The ends are soldered together. the Wire is 12 inches long
I've been thinking about doing version 2.0...
As it turns out, ordering some 3" (actuallly 3.17") diameter cupcake holders worked out really well! They were inexpensive, quick, and easy to cut. Also, There was a decision to add venting holes for Otter's condition. Cutting it from the button to top seemed to prodcue the best results.
The edges need to be cleaned up a bit... it seemed the the bulb tip actually worked better than the razor blade tip... E6000 glue works incredibly quickly when setting the two materials together...
We wanted to utilize a Quick Release Cat Collar clip into the design... ultimately I ended up purchasing some quick release collars, cannibalized the clips and went with a simple loop with the velcro straps... To remove the clips I used a razor blade attachment on the wood burning tool (I got the blade tip from Michaels)
Here are some pics of Digital iterations of Helmet Ideas:
HA! You gotta check out the Instagram page! It's amazing!
https://www.instagram.com/babykittenrescue/
i just love that photo of him sticking out of his crate , he looks like some weird highly advanced space creature that crash landed his escape pod, he's got this, "did you just see that shit!" face, adorable !
