1Create the Software Stack for your Bespoke Application.
The resources to facilitate the creation of bespoke applications for Windows which can interface with either Arduino or Propeller via serial, USB, Bluetooth, or TCP/IP are provided in the GitHub repositories. Thus the "propeller debug terminal C++ port" provides the ability to create such projects within Visual Studio 2005 or later. Visual Studio 2005 is a nice IDE to work with because it is the only version that I know of that provides backward compatibility (if desired) to create projects that will run under Windows 95/98/ME/NT/XP/Vista/7/8/10/ and 11! Later versions of Visual Studio break 9x support and therefore might have some integration issues with WINE support, that is - if WINE support is needed or desired - which of course it will be.
2Getting out of the Sandbox.
Once you have a working bespoke application, congratulate yourself on graduating from the manufactures sandbox! Integrate with real-world hardware according to your liking! Enjoy! Several possible hardware configurations were discussed in previous projects, i.e., see some of my projects from 2019-2021 for ideas on how to put together a new robotics concept for STEM use, or build a digital logic analyzer/spectrum analyzer.
3Conquer the Universe.
You will have to figure this one out on your own. This is after all a universal project that begins with serial port interfacing and then does EVERYTHING!
