Teensy / Arduino eurorack sequencer
Drum / voltage sequencer
Design a feature rich drum machine type sequencer with arduino or teensy. 16 channels
16x channels
16x physical steps (chainable)
4x cv out channels
Midi in and out
Per step polyphony (maybe not all channels)
  • Tested outputting to lots of LEDs via shift registers
    Lee Sampson6 days ago 2 comments
    I wanted to figure out the best way to run many LEDs quickly without using loads of IO pins. Here I tested using shift registers. I tried two methods, shiftOut() and SPI. I ran a test setting 16bits and recorded the time. Results:
    - shiftOut() = 204 μs
    - SPI = 16 μs
    Clearly SPI is much faster. Below are both methods.
    SPI Schematic:
    SPI test code:
    #include <SPI.h>
    //int pll_d=11; //piedino data
    //int pll_c=13; //piedino clock
    int pll_l=10; //piedino latch
    #define DATAOUT 11//MOSI
    #define DATAIN 12//MISO
    #define SPICLOCK 13//SCK
    int timer = 0;
    uint16_t ledNumbers[17] = { 0b0000000000000000,
                                0b1000000000000000,
                                0b0100000000000000,
                                0b0010000000000000,
                                0b0001000000000000,
                                0b0000100000000000,
                                0b0000010000000000,
                                0b0000001000000000,
                                0b0000000100000000,
                                0b0000000010000000,
                                0b0000000001000000,
                                0b0000000000100000,
                                0b0000000000010000,
                                0b0000000000001000,
                                0b0000000000000100,
                                0b0000000000000010,
                                0b0000000000000001};
    void setup () {
      pinMode(DATAOUT, OUTPUT);
      pinMode(DATAIN, INPUT);
      pinMode(SPICLOCK,OUTPUT);
      pinMode(pll_l, OUTPUT);
      SPI.begin();
      Serial.begin(9600);
      SPI.setDataMode(SPI_MODE0);
      SPI.setBitOrder(LSBFIRST);
      SPI.setClockDivider(SPI_CLOCK_DIV2);
      timer = micros();
      digitalWrite(pll_l,LOW);
      SPI.transfer(ledNumbers[0]);
      SPI.transfer(ledNumbers[0] >> 8);
      digitalWrite(pll_l,HIGH);
      timer = micros() - timer;
      Serial.println(timer);
    void loop() {
      // put your main code here, to run repeatedly:
      for(int x = 0; x < 16; x++){
        turnOn(ledNumbers[x + 1]);
        delay(500);
    void turnOn(uint16_t bitNum){
      SPI.transfer(bitNum);
      SPI.transfer(bitNum >> 8);
    shiftOut() Schematic:
    shiftOut() Code:
    int DS_pin = 11;
    int STCP_pin = 12;
    int SHCP_pin = 8;
    uint16_t ledOutput = 0;
                                0b1000000000000000,
                                0b0100000000000000,
                                0b0010000000000000,
                                0b0001000000000000,
                                0b0000100000000000,
                                0b0000010000000000,
                                0b0000001000000000,
                                0b0000000100000000,
                                0b0000000010000000,
                                0b0000000001000000,
                                0b0000000000100000,
                                0b0000000000010000,
                                0b0000000000001000,
                                0b0000000000000100,
                                0b0000000000000010,
    void setup()
      Serial.begin(115200);
      pinMode(DS_pin,OUTPUT);
      pinMode(STCP_pin,OUTPUT);
      pinMode(SHCP_pin,OUTPUT);
      turnOn(4);
      delay(500);
      turnOn(8);
      delay(500);
      turnOn(12);
      delay(500);
      turnOn(16);
      delay(500);
      turnOff(4);
      delay(500);
      turnOff(8);
      delay(500);
      turnOff(12);
      delay(500);
      turnOff(16);
    void loop()
    void turnOn(int bitNum)
      ledOutput |= ledNumbers[bitNum];
      digitalWrite(SHCP_pin, LOW);
      shiftOut(DS_pin, STCP_pin, LSBFIRST, ledOutput);
      shiftOut(DS_pin, STCP_pin, LSBFIRST, ledOutput  >> 8);
      digitalWrite(SHCP_pin, HIGH);
    void turnOff(int bitNum)
      ledOutput &= ~ledNumbers[bitNum];
View project log
