socket_plate.stl
this plate goes inside the case to fix the socket from the inside
Standard Tesselated Geometry -
29.57 kB -
09/30/2022 at 06:19
Download
socket_2.stl
the socket mount to fit the display onto the c64 case
65.90 kB -
09/30/2022 at 06:18
Download
side-plate_u64.stl
side cover for the Ultimate64. this has the openings for joystick and power connector
82.89 kB -
09/30/2022 at 06:17
Download
display_blind.stl
for covering the open part of the middle layer, below the dvi, hdmi, and vga connectors
684.00 bytes -
09/30/2022 at 06:16
Download
cover3.stl
Cover for the display-control keypad
63.17 kB -
09/30/2022 at 06:16
Download
display_tft_middle_6.stl
The middle panel of the display enclosure. Here, the display driver panel is mounted
171.96 kB -
09/30/2022 at 06:14
Download
display_tft_front.stl
The front-panel of the display enclosure. This is the frame for the actual display
39.93 kB -
09/30/2022 at 06:14
Download
display_tft_back.stl
The back panel of the display enclosure. This holds power and composite jack, and it has the openings for HDMI and the display-control keypad
145.10 kB -
09/30/2022 at 06:14
Download
