USB charger plug holder
The USB-C charger plug for my laptop easily falls out if the PC moves a bit. This holder keeps the plug in place
0 followers
Even though the universal USB-C chargers were a step forward I miss the Lenovo USB-A type charger plugs. They stayed inserted. On the contrary, small movements of the PC easily cause USB-C plugs to slip fully or partly out. This holder is pushed on to the laptop, in this case a Lenovo Thinkpad T490 and effectively keeps the plug in place.
I used OpenScad to design the holder and by changing parameters it may be adjusted to fit other laptops. See below for the design and STL files.
usbholder.stl
The 3D print file
Standard Tesselated Geometry - 53.40 kB - 11/25/2022 at 23:21
Download
usbholder.scad
The OpenScad design file
scad - 3.24 kB - 11/25/2022 at 23:20
Download
