Today I will show to how to make How to Make Voltage Regulator using LM317, 10K potentiometer and Resistor 270
All the material you need for this project:
![](https://cdn.hackaday.io/images/125871670401065019.jpg)
![](https://cdn.hackaday.io/images/5878601670401066137.jpg)
Here are the steps of this project:
![](https://cdn.hackaday.io/images/4431311670401097349.jpg)
![](https://cdn.hackaday.io/images/1429181670401097497.jpg)
![](https://cdn.hackaday.io/images/8363621670401097565.jpg)
![](https://cdn.hackaday.io/images/8955381670401097684.jpg)
Show results:
![](https://cdn.hackaday.io/images/6148791670401109629.jpg)
![](https://cdn.hackaday.io/images/8625821670401109663.jpg)
The product links as below:
IC chips: https://www.utsource.net/category/ele...
Modules: https://www.utsource.net/Modules?sour...
Passive components: https://www.utsource.net/PassiveDevic...
Sensors: https://www.utsource.net/home/sensors...
LED lightings: https://www.utsource.net/category/led...
More electronic components you may be interested:
SN74HC14N https://www.utsource.net/itm/p/1431645.html
V9958 https://www.utsource.net/itm/p/1872435.html
74HC14N https://www.utsource.net/itm/p/11226445.html
MN3102 https://www.utsource.net/itm/p/11743715.html
NE555N https://www.utsource.net/itm/p/11198941.html
For more details, pls check the video on youtube:
