Yes, I know, there is still no news about the case, so, at least something simple....
I try to put this soldering pen into transparent shrinkable tube (ø 10 mm) and seems with very good success, buttons are easy to press, so very good and cheap protection.
.... but one small fail, I forget to put down the protecting foil from the display! ,-D
is there any news on a case design yet ? I’ve seen a few but all seem to lack any sort of mechanical support to take strain off the 3.5mm connector.
Hi there mr.vlk
I got 1 question about the rt soldering case.
Are you planning to make the case with mr.Otto Winter or you are going to make 1 made by your self ?
Thanks .
http://global-motions.com/ftp/Weller-RT6-Case2.jpg
Hi Ivan, I working on my own design.
Thanks for asking.
Ok,thanks you very much :)
Hi vlk,
Nice iron, just bought one.
Can you share a 3D model to print a proper enclosure?
Thanks for purchasing, 3D model is still not done, some prototype will be soon
This actually looks pretty good. I wonder if you could just cut some holes in a magic marker, for another improvised case.
