stepper1test.ino
This is the Arduino source file. You can enable a serial debug terminal by uncommenting the #define
ino -
17.77 kB -
12/25/2016 at 12:27
Download
gear for vacuum bar.stl
Standard Tesselated Geometry -
896.37 kB -
12/25/2016 at 12:21
Download
baseplate.stl
694.01 kB -
12/25/2016 at 12:21
Download
moving plate.stl
496.79 kB -
12/25/2016 at 12:21
Download
stepper motor holder.skp
SSEYO Koan Play File -
171.75 kB -
12/25/2016 at 12:21
Download
bearing holder for 6mm drive belt.skp
191.62 kB -
12/25/2016 at 12:21
Download
sidecoverfront.stl
195.11 kB -
12/25/2016 at 12:21
Download
seed holder tria.skp
162.37 kB -
12/25/2016 at 12:21
Download
front panel plate.skp
194.90 kB -
12/25/2016 at 12:21
Download
sidecover1.stl
76.75 kB -
12/25/2016 at 12:21
Download
back panel plate.skp
170.62 kB -
12/25/2016 at 12:20
Download
gear for vacuum bar2.stl
851.52 kB -
12/25/2016 at 12:20
Download
pulley bearing for 13mm bearing.skp
188.23 kB -
12/25/2016 at 12:20
Download
bearing holder for 6mm drive belt top side.skp
189.99 kB -
12/25/2016 at 12:20
Download
back panel plate.stl
61.85 kB -
12/25/2016 at 12:20
Download
front panel plate.dxf
AutoCAD DXF -
40.09 kB -
12/25/2016 at 12:20
Download
belt holder for main plate.stl
211.65 kB -
12/25/2016 at 12:20
Download
stepper motor holder.dxf
AutoCAD DXF -
44.86 kB -
12/25/2016 at 12:20
Download
belt holder for main plate.skp
221.14 kB -
12/25/2016 at 12:20
Download
stepper motor holder.stl
46.68 kB -
12/25/2016 at 12:20
Download
front panel plate.stl
41.39 kB -
12/25/2016 at 12:20
Download
horizontal joiner plate.skp
188.33 kB -
12/25/2016 at 12:20
Download
bearing holder for 6mm drive belt.stl
141.43 kB -
12/25/2016 at 12:20
Download
bearing holder for 6mm drive belt top side.stl
140.05 kB -
12/25/2016 at 12:20
Download
vacuum side vertical panel.skp
181.93 kB -
12/25/2016 at 12:20
Download
back panel plate.dxf
AutoCAD DXF -
66.45 kB -
12/25/2016 at 12:20
Download
pulley bearing for 13mm bearing.stl
97.86 kB -
12/25/2016 at 12:20
Download
top moving plate.dxf
AutoCAD DXF -
45.83 kB -
12/25/2016 at 12:20
Download
seed holder tria.stl
25.59 kB -
12/25/2016 at 12:20
Download
horizontal joiner plate.stl
139.84 kB -
12/25/2016 at 12:20
Download
vacuum side vertical panel.stl
88.84 kB -
12/25/2016 at 12:20
Download
top holder plate belt side.skp
190.32 kB -
12/25/2016 at 12:20
Download
vacuum side vertical panel.dxf
AutoCAD DXF -
96.06 kB -
12/25/2016 at 12:20
Download
pulley bearing for 13mm bearing 6.75mm radius.stl
106.35 kB -
12/25/2016 at 12:20
Download
vacuum nozzle.stl
185.32 kB -
12/25/2016 at 12:20
Download
horizontal joiner plate.dxf
AutoCAD DXF -
127.54 kB -
12/25/2016 at 12:20
Download
endstop holder x axis.skp
174.84 kB -
12/25/2016 at 12:20
Download
top moving plate.skp
170.42 kB -
12/25/2016 at 12:19
Download
belt side vertical panel.skp
185.81 kB -
12/25/2016 at 12:19
Download
top holder plate belt side.stl
154.67 kB -
12/25/2016 at 12:19
Download
belt side vertical panel.stl
107.53 kB -
12/25/2016 at 12:19
Download
belt side vertica panel.dxf
AutoCAD DXF -
103.29 kB -
12/25/2016 at 12:19
Download
vacuum nozzle.skp
206.95 kB -
12/25/2016 at 12:19
Download
gear for vacuum bar2.skp
350.30 kB -
12/25/2016 at 12:19
Download
seed fall tube 5x.stl
458.50 kB -
12/25/2016 at 12:19
Download
top hoder plate vacuum side.stl
204.32 kB -
12/25/2016 at 12:19
Download
gear for vacuum bar.skp
373.54 kB -
12/25/2016 at 12:19
Download
top moving plate.stl
43.97 kB -
12/25/2016 at 12:19
Download
seed fall tube 5x.skp
304.46 kB -
12/25/2016 at 12:19
Download
top holder plate vacuum side.skp
204.02 kB -
12/25/2016 at 12:19
Download
vacuum encap.skp
172.86 kB -
12/25/2016 at 12:19
Download
endstop rotating axis stopper.skp
177.98 kB -
12/25/2016 at 12:19
Download
endstop holder rotating axist.skp
174.71 kB -
12/25/2016 at 12:19
Download
endstop rotating axis stopper.stl
68.40 kB -
12/25/2016 at 12:19
Download
endstop holder rotating axis.stl
28.64 kB -
12/25/2016 at 12:19
Download
seed holder tray left side.stl
25.17 kB -
12/25/2016 at 12:19
Download
endstop holder x axis.stl
47.15 kB -
12/25/2016 at 12:19
Download
